Searching for a good cam... pls help
Old Jul 25, 2008 | 10:24 AM
rossp's Avatar
Default Searching for a good cam... pls help
Well first off im new to these ls motors and i have a 4.8 that i am putting in
2wd toyota pickup. I dont want to do the swap without getting myself a cam first. The is my dd but will see the strip for sure. I will be running th350 with a 2300 stall t/c. Can anyone shoot me in the right direction for a cam?
Old Jul 25, 2008 | 12:14 PM
sickREDsierra's Avatar
i would go 206/212 low lift comp grind on a 112 LSA
but thats just me.
might want to do more reading and come to an exact goal with what you expect from the cams power range and with that small TC.
http://www.compcams.com/Cam_Specs/Ca...csid=1095&sb=2
Old Jul 25, 2008 | 12:17 PM
00ChevyScott's Avatar
Wearin' da big hat
Its going to be going in a toyota, so he wont have the problem of it being in a big heavy truck. Id say at least a 220/220
Old Jul 25, 2008 | 12:20 PM
viciousknid's Avatar
Where's the Beef?
Read any of the hundreds of cam threads and you'll come to the same results.
It all depends on what you want to do with the vehicle.
Just remember that in theory the larger the duration the higher your rpm range is going to be and the less low end tq your going to have.
Find out where you want power and then start looking at cams and look at the rpm range that cam produces power.
Personally i'd get the largest duration and lift I could get that is within a chosen range.
In order to give you the most help, we are going to need to know what your goals are.
Old Jul 25, 2008 | 10:41 PM
rossp's Avatar
First id dont want to completely kill my gas mileage... it will have a small shot of nitrous (nobigger than a 100 wet shot). Still needs to be driveable everyday but it WILL see the strip alot. With my converter i would like my power range to be around 2000-62 or 6500.
Old Jul 26, 2008 | 05:32 AM
Where's the Beef?
If it's the toyota in your avatar, don't worry about mileage, your going to be fine there.
With a truck that light and hitting the strip a lot. I'd go 2600-3000 stall and maybe a 220/220 cam. shouldn't take much to get that thing moving so low end tq isn't as much of a priority. Tuned properly your going to looking at some pretty good highway miles even.
Bumpers
Aug 4, 2024 09:44 PM
DrX
Aug 19, 2015 04:45 PM
Denali08
Aug 9, 2015 04:34 PM
LARRY01Z28
Aug 1, 2015 10:15 PM
Bluecollar Hotrods
Jul 26, 2015 09:56 PM
