In search of lower IAT's
Old Jul 25, 2012 | 07:19 AM
PWRVTEC's Avatar
I have the stock airbox with ribs smoothed out and inside coated in a boat resin, bottom has a 4" opening with a 4" aluminum tube running down to just above the fender-well lining, and a Arid MIT and my IAT runs about 110 in traffic on a 95 degree day. On the move its about 98-105 it really works well. Don't worry about thinking water will get in as I still have the factory openings so even if the tube is in water the least resistant path will draw the air. Kinda like those AEM CAI bypass valves.
Old Jul 25, 2012 | 09:16 AM
Vortec350ss's Avatar
Andy I'd be interested to see how you routed that tube to the intake. Any help to get cooler air to the filter is worth it IMO. I never removed the plate below my intake either... I really need to take the time to do that.
Old Jul 25, 2012 | 09:34 AM
AndysC3's Avatar
Going up to the air box
How it was routed with the Volant air box.
I cut a 4" hole in the metal plate thats under the intake.
Old Jul 25, 2012 | 09:51 AM
nonnieselman's Avatar
if you relocated the IAT to the EGR port. it will heat soak fast from the engine heat rising and the manifold warming up.
but a quick hit on the throttle and it drops fast.
Old Jul 25, 2012 | 10:48 AM
mvrk10256's Avatar
Hang on. The IAT sensor is a sensor. If you relocate the sensor it wont change the actual intake temperature of the air, you will just be reading the temp from something else.....
Old Jul 25, 2012 | 11:42 AM
ayousef's Avatar
im against that aluminum tube, that thing would get heatsoaked like anything! ask me how I know...
Old Jul 25, 2012 | 12:00 PM
Thats pretty cool... dunno how well it would work with the K&N open air filter set up though.
Old Jul 25, 2012 | 12:05 PM
charcoal03silvy's Avatar
The stock IAT sensor in the MAF is junk...
Old Jul 25, 2012 | 04:24 PM
2007chevy5.3l's Avatar
Pretty much what he said. You can get way better sensors that are more accurate and are alot faster, unlike the stock MAF IAT sensor
Old Jul 25, 2012 | 08:49 PM
Idryfly5's Avatar
ditch the aluminum tube for a plastic one. or heat wrap the tube to prevent some heat soak?
