Sea Foam
Old May 2, 2005 | 07:11 PM
Ok i was going to put the sea foam in today. I started it up and took the brake booster hose off. The truck started sputtering and it was wanting to die. I tried to rev it up put it just kept sputtering worse and finally died. Is it suppose to do this? I haven't put any in yet. I was just wanting to know if this is normal? It would barely run with the hose off
Old May 2, 2005 | 07:32 PM
budhayes3's Avatar
PT's Slowest Truck
Yea, it's gonna want to stall with the booster hose off since that create's a huge vacuum leak. You can try cracking the throttle a little bit (use a screwdriver or matchbook wedged between the set screw) to keep the RPM's up while you do it.
Old May 2, 2005 | 10:30 PM
dust6928's Avatar
find a smaller vacuum hose
Old May 2, 2005 | 11:51 PM
MrXerox's Avatar
Put your thumb over the open end of the brake booster hose to create a small opening and slowly pour the can down into the hole...The vacuum will suck down the fluid so it will not spill everywhere.
Zizzle
Oct 19, 2017 08:44 PM
Suburban2500
Jul 19, 2015 04:50 PM
mason110
Oct 9, 2005 07:08 AM
Mr. Sandog
36
Jan 25, 2005 03:00 PM
