SD questions
When SD tuning and inputting the data and making adjustments what does the different color changes mean in the table? Also I know your supposed work your way through the throttle slowly to hit more cells and all that but should I be doing higher rpm's/WOT pulls? (as long as I don't run lean) and while logging data at different times with different outside temperature say a 10 to 15 degrees difference will this effect my data and accuracy of the tune?
thanks in advance
thanks in advance
gasmachine85
Jun 14, 2012 03:05 PM
