same cam in 5.3 vs ls1 5.7
Old Feb 15, 2005 | 10:46 PM
02sierraz71_5.3's Avatar
Default same cam in 5.3 vs ls1 5.7
If you where to put a tr224 in a 5.3 versus an ls1 5.7 what would the differences be as far as rpm range, drivability, mpg etc...
looking to put it in my 5.3 sierra but dont want to loose lower tq numbers will the stall make up for it
have 3k stall
Old Feb 15, 2005 | 10:57 PM
FILE's Avatar
Your power band would move up in the 5.3. Your 3k stall will perfect.
Old Feb 15, 2005 | 11:09 PM
the heads are being milled .05 with bigger valves, Im hoping the 224 will be good in this setup
Im worried about piston to valve I cant afford to do this again or kill the motor
Old Feb 16, 2005 | 09:29 AM
TigerFan187's Avatar
That cam would work nicely with your 5.3 and 3000 stall!
Old Feb 16, 2005 | 01:32 PM
Sport Side's Avatar
The rpm range will stay the same, given the same head/cam/intake. The 5.3, 5.7, & 6.0 use the same stroke. The smaller piston (bore) will only shroud the valves more, causing you to use the smaller valve given (1.89). Tucking a 2'' might not be the best idea.
The TR224 wont be your best choice either for low end torque.
GrooveCityZ71
Aug 31, 2015 12:05 PM
Denali08
Aug 9, 2015 04:34 PM
vmaxpro
Aug 4, 2015 07:02 AM
steves86ta
Jul 28, 2015 10:21 AM
grantpo
Jul 15, 2015 12:21 PM
