S/C 6.0
Old Oct 14, 2003 | 04:58 AM
Default S/C 6.0
Who all has a 6.0 with any kind of SC? If you do please list what mods you have done to the motor and what type of SC you are running and what kind of power you are throwing down to the wheels. thanx ahead of time.
Old Oct 14, 2003 | 07:38 AM
L82gofast's Avatar
Default Re: S/C 6.0
I am running the original magnacharger (5.5-6psi) on a stock motor. The rest of my mods are in my sig. I have never dyno'ed it but my Gtech says its moving 5800lbs+ at 15.1-15.2
A radix on your truck would be nothing short of awsome
You would need to start a savings account for tires....
Old Oct 14, 2003 | 11:56 AM
David Cairns's Avatar
Default Re: S/C 6.0
I have the Radix on my SS. A slightly different 6.0 than you have. (the LQ9 vs the LQ4, higher compression being the main difference). I have not dynoed my truck, so I don't have any numbers on that. I do know the 1/4 mile time went from 15.3 to 13.9 with just the Radix. I have no other engine mods. I am thinking about a Corvette servo for the transmission to speed up the 1-2 shift.
Here is a chart showing the data collected from EFILive on a stock SS and my supercharged SS.
Old Oct 14, 2003 | 01:10 PM
FarmTruc's Avatar
Performance Trucks Sponsor
Default Re: S/C 6.0
Nice numbers Cairns, I'll be installing another Radix on a '03 SS, I hope the results are very similar.
The truck has shorties and dual exhaust, TB spacer.
We'll be heading out to the track to get some before and after track runs.
I'll keep you updated,
allen
Old Nov 12, 2003 | 12:49 PM
how easy is it to install the magnacharger radix? Did ya'll run into any problems when installin it?
Old Nov 12, 2003 | 01:17 PM
tbyrne's Avatar
I ran the side mounted Magnuson on a 6.0 Suburban a few years ago. That system is no longer in production. It has been replaced by the Intercooled RADIX kit -
This system is very popular and usually good for a 130+hp increase. More power is just a pulley swap away. The installation really isn't to bad. An extra set of hands will make life easier when you lower the new manifold/supercharger between the heads.
Tom
Old Nov 12, 2003 | 02:49 PM
GMC SKI's Avatar
Wait a few weeks and get a Single turbo kit from Cobination motor sports
That's what I'm going with no Belts to worry About
and just as efficient as the radix I'm sure
Btw I'm running a Procharger with 8lbs of boost it made 535rwhp and 500rwtq
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
