Rotating assembly for 408 stroker
Old Jun 17, 2016 | 09:28 AM
Vortec350ss's Avatar
Yea... what they said.
Old Jun 17, 2016 | 09:18 PM
GREENSIERRA's Avatar
FWIW I run a K1 crank, compstar rods and weisco pistons in my 408.
mine is a similar build to you but I am nitrous
Old Jun 18, 2016 | 01:36 AM
Blown06's Avatar
8 Second Truck Club
There is a head gasket that I believe was pioneered in australia and guys are pushing big boost on them. They are a 4 bolt gasket, but the most successful I've seen so far have been with them used on 6 bolt motors with 1/2" studs........I'm talking like 45-50 lbs of boost. There's lots of info about them over on the bullet.
The only issue though is like I said.....there isn't a ton of people using them yet and you really have to pay attention to the combos with them. These are built motors likely filled with big studs on methanol.......so it's really hard to see how well they actually work by themselves. The gasket has been cut out around the bore and uses a special ring that sits inside the gasket bore to seal on the head.
The gaskets are getting high praise, but like I said, 40+ lbs of boost is nothing new so you have to be careful about doing the monkey see monkey do ****. There is a dude with a fox body that claims a stock bottom end (it has been extensively worked but uses stock components) that runs 40-42 lbs of boost on stock heads and cometics and has been successful so take that however you want...........
The key things that I see that most don't like to mention right away is that these big boost guys are using blocks that are full filled, don't run water, have big studs and run methanol as fuel.
Old Jun 18, 2016 | 10:10 AM
muddybowtie's Avatar
Awesome! I'll definitely take a look into those parts as well! It's good to see someone with a similar build on here. I expected mostly street trucks!
Old Jun 19, 2016 | 01:20 AM
Blown06's Avatar
8 Second Truck Club
Matter of fact.....Texas Speed is now stocking these gaskets. Here's a link
https://www.texas-speed.com/p-5046-p...re-single.aspx
Happy boosting my friends
LPCWS6
Apr 15, 2016 07:05 PM
40series
Apr 14, 2016 02:51 PM
ironcityboom
Apr 9, 2016 08:20 PM
lxcoupe
Apr 5, 2016 10:05 PM
regency
Mar 20, 2016 07:10 PM
