rocker arms
I have been running the HS 1.7's for a while now too. No issues with the arms themselves. Same as budhayes, had to clearance the PCV **** inside the valve cover, nothing a dremel didn't make short work of, after i found where it was hitting.
I did have a bolt break on me, after a hard downshift and romp while merging. Scared the hell out of me, made quite a racket. pulled the cover, took out the broken piece, a trip the sears hardware and it was all fixed.
how will a rocker arm affect lift duration? I can't see how thats possible.
Im ending up going with the comp trunion upgrade. The stock rockers work great and with the upgrade it pretty much eliminates any way of needle bearing failure.
I am going to get it later though. The engine is going in Wednesday and im just going to use the stock rockers for now. Get the comp upgrade later.
The "quick lift" geometry in the crane rockers somehow gets the valve off(and on) the seat quicker, and "seemingly" adds duration, while increasing valve lift at the same time. They work very well, but I think alot of guys are not willing to pay the price.
These are the rockers that I run as well. The initial setup/adjustment is tedious work, but I haven't had to touch them in over 40,000 miles. I also liked getting rid of the factory stretch bolts for the ARP studs & pushrod guideplates that come with the kit.
