Returnless Fuel Module Observations
Old Dec 12, 2006 | 11:35 PM
  #21
TURBHOE's Avatar
i think i'll try my chances with the intank setp lol. those thing are alittle pricey.
Old Dec 12, 2006 | 11:39 PM
  #22
DrX's Avatar
DrX
Originally Posted by 4.8T
not to sure how i would make one of those. didn't you say you hooked something to something else and it filled the bucket better. or something like that.
I just restored the venturi pump feature that was originally driven by an extra outlet on the bottom of the factory pump. In my case that would at least require a suitable T-fitting, an extra length of teflon flex tubing, some 1/8 nylon tubing and suitable hose clamps.
Old Dec 13, 2006 | 12:02 AM
  #23
TURBHOE's Avatar
i guess when i get it apart when its time i'll look at it and figure it out from there. i just hope your online when time comes. so feb, march of next year keep a look out for pm's from me.
Old Jul 7, 2007 | 12:10 PM
  #24
wkdivr's Avatar
Originally Posted by DrX
The impression I get is that the truck modules perform a little better. Haven't seen one up close but it looks like the regulator setup is different. If the venturi pump is driven off the regulator rather than the pump, then you wouldn't lose that important feature of the factory module by upgrading to a Walbro. I would like to see some pics of the module and stock pump out of a truck.
Bringing this back from the dead (or near dead)
I'll get some posted up later tonight.
Old Jul 7, 2007 | 12:52 PM
  #25
wkdivr's Avatar
Here's the filter and reg out of my truck
Looks like the regulator dumps fuel back into the tube that leads to the venturi. What if you took all this stuff out of the bucket, and ran an outside reg, then ran the return directly back into the venturi tube?
Disassembled for clarity. (maybe)
04 connector
03 connector, maybe the same as f-body
Big size difference from 03 (small one) - to 04 (big one)
Remember, these are disassembled at some stage
Old Jul 7, 2007 | 03:32 PM
  #26
DrX's Avatar
DrX
Good pics. Confirms what appeared to be the case from other pics I have seen. The waste from the FPR drives the venturi pump so that function is not lost when you do the Walbro pump swap. This is why the trucks perform better than the Avalanches after the swap. Looks like your plan for a return style conversion might work with this bucket style. Will also give you more reserve if the filter was on the inside of the bucket.
What are the dimensions of that 04 bucket(height, diameter)? Center to center of the 2 rods?
Any pics of the bottom outside of the 04 bucket? Shots looking down into the empty bucket?
Old Jul 7, 2007 | 03:47 PM
  #27
DrX's Avatar
DrX
Maybe you could even drop a second bucket/walbro in the tank alongside the main one and split the return to both of them.
Old Jul 8, 2007 | 07:26 AM
  #28
wkdivr's Avatar
I'll get more pics today
Old Jul 8, 2007 | 08:44 AM
  #29
DrX's Avatar
DrX
What connects to the nipple on the top of the FPR? Looks like there 2 ports on top of the filter. Is that correct?
Old Jul 8, 2007 | 10:34 AM
  #30
wkdivr's Avatar
Actually, the little nipple on the fpr looks to be a vacum nipple, like it's the same one used up on the rails, on the earlier models. Nothing connects to it in this instance.
