Removing Oil Cooler
I just bought a 6L LQ4 engine with only 12,000 miles on it. I bought it because I got it pretty cheap. I intend to install it in a first generation Camaro sometime this summer. The engine has provisions for an oil cooler with the two oil lines connected at the engine just above the oil filter. I don't think I will use an oil cooler in the Camaro as I doubt they’re needed for such a light car. Any suggestions on how I can block the two holes in the oil pan where these two oil lines are connected?
Thanks,
Pikanjoe
Thanks,
Pikanjoe
Trucks that did not originally have an oil cooler just have a little blockoff plate in the location you are describing. It is only a few bux from the stealer, and remember to get the gasket for it too.
Pikanjoe
GXPJAY
Feb 13, 2022 08:15 AM
D1SCSS
Jan 25, 2016 10:14 PM
ullose272
11
Jul 17, 2015 07:22 AM
