removed TB spacer=problem??
Old Jul 16, 2005 | 02:39 PM
TXsilverado's Avatar
Default removed TB spacer=problem??
last night i replaced my stock throttle body with a S2. i had my GF floor it with the truck off and it hit the bump stop fine. today i decided to remove my helix tb spacer. when i took it out for a drive i found that it shifts 1-2 at 5000 instead of 6000. so i start trouble shooting and figured out that the throttle isnt making it to the bump stop.
i dont know how far its missing by because i just rubbed grease on the bump stop and it never made it to the throttle mover thingy(nobody to help).
will the computer learn to make up for this lack of throttle or do i need to adjust something?????
help
Old Jul 16, 2005 | 03:04 PM
TigerFan187's Avatar
I smoked alot of crack Today!!!!
Old Jul 16, 2005 | 03:06 PM
dont get what your asking
Old Jul 16, 2005 | 03:26 PM
ThunderZ28's Avatar
12 Second Club
Originally Posted by TigerFan187
Theres no wat that the pcm is that far off from a TB is there???
LOL
have a little to much to drink Tiger??????
stewart you may need to adjust the cable.
and/or remove the throttle cable bracket that came with the spacer. that mounts on the top of the intake
Old Jul 16, 2005 | 03:35 PM
ramjet502's Avatar
sounds like you linkage is off the throttle body spacers usally come with the kit to make you linkage work with the spacer did you put it all back the way it was before the spacer was on it?
Old Jul 16, 2005 | 04:10 PM
one03sierra's Avatar
Formerly one92rs
Talking
thats what i was going to ask. did you take the linkage spacer off.
Old Jul 16, 2005 | 04:17 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Old Jul 16, 2005 | 04:31 PM
i didnt install the spacer(it came on the truck) so i didnt know there was a linkage thingy. will it be easy to figure out what it is?
Old Jul 16, 2005 | 04:35 PM
Formerly one92rs
Talking
yes sir it will. should be a flat piece if aluminum where the linkage bolts up on top of the intake. remove it completely and reinstall the linkage without it. if you arent far come on over and ill fix it for you. lemme know if you need some help. pm sent.
Old Jul 17, 2005 | 11:35 AM
thanks for the help guys. it was that linkage bracket.
