reduced engine power...HELP!!!
Old 07-22-2009, 07:09 PM
truckmann's Avatar
Originally Posted by lucky77
i think it has something to do with voltage . . i had a reduced power several times at WOT runs'
On a side note I think this issue might be different. You may need some adjustment in your tune for this case. I think you are reaching the limits in the Calc Airflow - P1514/P0068 error table which will cause the reduced engine power mode. I had this problem a couple of times after installing my cam and had to raise the values since I was getting more airflow than expected by this table at WOT on occasion.
Old 07-23-2009, 07:19 PM
03rado5.3ls's Avatar
i had the same problem with my 03 dbw engine reduced power I replaced the throttle body and it went away
Old 07-23-2009, 11:30 PM
terravast4's Avatar
I ordered a new throttle body as the ls 2 have no serviceable parts. Not cheap at all. Local dealer said $540 my dad has a friend and got me one for $195 plush shipping but no one stocks htese units. What a ******* pain.
Old 07-24-2009, 05:42 AM
RED04REGENCYRST's Avatar
i ran into this problem also at first then i adjusted the same table that truckmann did. that fixed my problem down low, but i was still goin into rep mode at wot. i change tbs and tac modules and the gas pedal. i couldnt get it to go away. then i got the new version of hpt, the beta version that is currently out and they had a tab in there to adjust the amount the tb opens and the area of air flow at different tb opening %. i made a few adjustments and the problem is completly gone now. it seemed that the x-link was puttin the tps out of voltage range and would trip the rep mode. so i set the tb to the max setting that tb would go before tripping the rep mode.
Old 07-24-2009, 01:16 PM
terravast4's Avatar
I will keep that in mind if I have anymore issues
Old 07-27-2009, 03:18 PM
terravast4's Avatar
bad x-link. chaged the TAC module and harness and no more problems. Now I got an extra 90mm TB.
Old 07-27-2009, 03:29 PM
KySilverado's Avatar
Originally Posted by KySilverado
My 1st X-Link module crapped out. Reduced power and those codes. I verified it by putting the old harness and 02 tac module on it and it cleared up.
Hmmmm... ding ding ding.
Glad you got it going. FWIW my second x-link has been trouble free.
Old 07-27-2009, 11:31 PM
terravast4's Avatar
Yeah, I will get another one. Grant at torque rush offered to send me a new one if I pay for shipping so i think that is a pretty fair deal.
Old 05-29-2010, 10:45 AM
TurboGibbs's Avatar
I have been having problems like this for 2 + years intermitently. I already adjusted the P1514 table long before the X adapter. REP started with WOT runs. It has been off and on while normal driving with P2135 codes and sometimes P0220. Today it is non-stop going in REP and P2135 after resetting codes with my interceptor gauge. Maybe a 30 second delay between clearing codes and REP again.
I haven't replaced anything yet but have always had a hunch about the x link cable. It has been just a PITA but now it isn't drivable. Any other insight is appreciated.
Old 05-31-2010, 06:57 PM
terravast4's Avatar
I had to switch to the 02' tac module and the apropriate tb wire harness...problem solved.
Quick Reply: reduced engine power...HELP!!!
