Ran slower with the cutout open
Old Oct 13, 2008 | 05:11 PM
  #21
parish8's Avatar
single digit dreamer
like said above. one run doesn't mean much. i have ran back to back open and closed on several set ups. some na, some nitrous, some boosted. sometimes on the street with a gtech, sometimes at the track, sometimes at the dyno. i always picked up with open exhaust. picked up a little down low and more up top. typical in the 1/4mile NA was .1-.2 drop in et.
here is a dyno from a few years back. i can't remember the exact details but the chart and notes on the chart pretty much tell the story. i have charts that show 60rwhp by opening up the cut out but that was on a boosted set up.
Old Oct 13, 2008 | 05:16 PM
  #22
GMCtrk's Avatar
That's exactly consistent with my butt-o-meter. Is that a 5.3 or 6.0?
Old Oct 13, 2008 | 05:19 PM
  #23
parish8's Avatar
pretty sure it was a stock 6.0
Old Oct 13, 2008 | 05:23 PM
  #24
GMCtrk's Avatar
mine put 267/296 in 2nd gear with 89 tune.
Old Oct 13, 2008 | 06:18 PM
  #25
outlawz2004's Avatar
Originally Posted by GMCtrk
yep that's what I was gonna say. The 6.0 needs to breathe more. 4.8 doesn't make good torque down low so it probably needs some good backpressure.
I dont know about that. My 4.8 likes it open. I usually run .2 faster with it open, and that is with a loudmouth I series muffler and dual exhaust so there isnt much restriction in the first place.
Old Oct 13, 2008 | 10:32 PM
  #26
budhayes3's Avatar
PT's Slowest Truck
I could see how it would lose some down low with it open, I bet that it would help at the top end of the track though.
Old Oct 13, 2008 | 10:36 PM
  #27
ChevyLee's Avatar
twin terbies
I lose some low end power with mine open, but it seems to pull harder after about 40 MPH.
Old Oct 14, 2008 | 05:51 AM
  #28
parish8's Avatar
that chart above starts at 2500rpm and there is allready a slight gain. maybe if your running a stock converter you could loose a little down really low?
Old Oct 14, 2008 | 10:38 AM
  #29
JOEFLO's Avatar
well personally i was doing 477 rwhp with the cut out close.then we decided to open it and it went down from a 477 to 470.i could fell it alittle weaker in top end .mine was a 6.0.guess my truck didnt like open exhaust. i lost 7 rwhp in the dyno
Old Oct 14, 2008 | 04:39 PM
  #30
parish8's Avatar
i would bet money that there was another factor in that test.
it could be a little lean on the closed run and then more lean to the point of loosing power when open.
if you were spraying might be lower bottle presure on the open run.
