Radix Pulley
Hey Im a newbie. My motor is being built right now at Keith Craft, its a 408. I have a Radix that I am putting on it. I was wonding if anybody new what the smallest pulley is that I can put on the blower. I want to max it out. I talk to Magnacharger and they said the blowers max RPMs it can turn is 14,000. The rest of the pulleys on the truck are stock. Can anyone on here help me figure that out.
You need to know the crank pulley size exactly. You also need to know how high you are going to be winding your motor. Then you can calculate Radix RPM's based on different Radix pulley sizes:
Crank Pulley
----------- X Engine RPM = Radix RPM
Radix Pulley
Crank Pulley
Radix Pulley
Well does anyone know what size the stock on is? Because I do know that it is a stock crank pulley. With my calculations right now with a 3.0 pulley im already over spinning the blower as it is. Im not too sure on this one im having a brain fart today.
Just checked the pulley that came with my Radix = 3.1". With the stock redline of 5800 RPM that would calculate to 14,032 Radix rpm, but the new motor will turn 6200 which calculates to 15000 at the Radix.
Is the 14,000 max for thermal efficiency (intake air temps) or unit failure protection?
