The Radix install
Well I started the install last night(4/22)at around 6pm to 9:30 Its fairly simple the instructions are a lil off nothin you cant deal with as they are for 99 year thru 02 I have an 03 imagine that any way so far so good no cusin or busted knuckles smooth sailin hopefully I can get started on it around 10:00 this mornin and have it rapped up at 2 or 3pm Ill keep you posted.
Well its 3:15 sat its installed and seem to be running fine I cant get on it because Lyndon Westers tune disabled the starter or some **** like that we tried to reset it with no luck Ill be gettin a new tune Wendsday but was able to drive home on the old tune and just took it easy for only a 10 mile ride home The install wasnt bad at all I think we may of had 7hrs with a few
breaks I did notice on the way home I had the vent on cold and hot air was blowing out and the a/c wouldnt work
so I have a few bugs to work out then Ill take er the track and see what the results are
breaks I did notice on the way home I had the vent on cold and hot air was blowing out and the a/c wouldnt work Trending Topics
Originally Posted by 03silverado5.3
Oh Thanks for offering a helping hand wkdivr(Bill). Hopefully the Tranny holds up for awhile so I can save some $$$$ for a built 4l65e.
Chris
definetly the transgo, might also think about billet accumulator pistons (to replace the plastic ones), a servo release check valve, corvette servo, and a transmission cooler if you dont already have one.
Lots of info if you search for transgo, 4l60e, sonnax.....heres one thread:
https://ls1tech.com/forums/showthread.php?t=180788
