Radix GT2-3, LS2 90MM TB Results 94 RWHP
#32
OK, will the GT2-3 cam work with 1.85 rockers I already have in the truck? also with the cam and 1.85 rockers will I still be ok with smog here in Calif.
Thanks
Thanks
#33
FormerVendor
Originally Posted by moregrip
you know, I was thinking about this thread today, about how popular the LPE GT2-3 cam has become, rightly so, as it does a very nice job in many different combinations. I wonder if this is a reflection of what most people REALLY want out of a cam vs. the typical I want lope or some lope, yada yada yada. With all the internet BS about how good this cam sounds and what not, maybe the real satisfaction comes from a "stock like" cam, that pulls the good numbers, has excellent daily driven street manners, etc etc.
2004Denali:
I'm not sure the 1.85 rockers are going to be kind to the valve springs with over .620"+ valve lift. You definitely will need to check to see if the valve springs can handle this much lift.
Richard
#34
I love seeing these kinds of results!
Personally Im gonna stick with my oddball cam (226/.591/116) and do all the basic stuff to wring out all the power I can on 5psi before switching out cam but IF I do switch I might try this cam out. If my new converter doesnt stall as high as I would like it to then I'll defiantely be switching cams and I'll talk Rick into doing the GT/2 or something very similar lol.
#35
I AM A MOTHERF*CKER
This test should have been run on a stock 1983 dodge colt tune and denatured methanol in the tires. The left turn signal should have been on the whole time, too, to help balance out the obviously over-power right hand blinker fluid resevoir found on those hybrid eatons. So, in all these results are worthless for the common user!
Once again, top notch thread, Brian. I didn't want you to get all soft with all the praise in this thread so I added some of what you are more used to
#36
Thanks! That is MUCH better!
#37
Originally Posted by Richard@WCCH
2004Denali:
Richard
Thanks
Mark
#38
Originally Posted by 2004Denali
I also have the behive springs, will this not work for me?
Thanks
Mark
Thanks
Mark
#39
Originally Posted by SS_bnoon_SS
The shape of the springs doesn't have anything to do with max lift values . Do you know the part number of the springs you are using?
26915-16
batch number 27139
installed: 105 lbs @ 1.200
open: 293lbs @ 1.200
Spring rate 313 lbs/in
coil bind 1.085
They are comp springs
And obviously this means nothing to me
Thanks guy
#40
This is what it says on the box
26915-16
batch number 27139
coil bind 1.085
Thanks guy
26915-16
batch number 27139
coil bind 1.085
Thanks guy
the 915's will be fine. I have used them in the past.
