Quick rocker ?.
Old Oct 29, 2008 | 05:02 PM
NegraRCSB2X4auto's Avatar
Default Quick rocker ?.
I'm in the middle completing a cam and head installation. When I tightened the rockers I noticed some are pressing down on the springs more than others. Because a couple of the push rods stuck out more that others. I thought they where all suppose to be even? Did i do something wrong when I installed the cam Or is this normal? Thanks
Old Oct 29, 2008 | 05:07 PM
thunder550's Avatar
High on diesel fumes
It's normal...no matter how you orient the cam, some of the lifters are going to be sitting on top of the lobes, which will open a couple of the valves.
Old Oct 29, 2008 | 05:08 PM
Mangled03gmc's Avatar
Baltimore Whore
Should be fine, the cam lobes are higher in some spots then other, the lifters are out of adj, sitting on the lobe.. To be safe tq down to 22lbs then bump the motor over a few times, check them again..
John
Old Oct 29, 2008 | 05:16 PM
sickREDsierra's Avatar
John
post *****.
but i agree. tq to 22 ft/lbs and roll the motor over a few times, tq again.. good to go.
Old Oct 29, 2008 | 08:52 PM
okay makes sense I should of thought about it before I asked the question.
thanks
Old Oct 29, 2008 | 08:55 PM
budhayes3's Avatar
PT's Slowest Truck
Just to further put your mind at ease, that's totally normal. (Does this make me a post ***** lol). If the rockers were all even, then all of the valves would be closed at the same time....or your pushrods would be way to short lol.
Old Oct 29, 2008 | 08:58 PM
Baltimore Whore
thanks
It happens
John
Wrecker 426
Oct 7, 2015 12:11 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
redbird555
Sep 30, 2015 09:28 AM
tim wellington
Sep 29, 2015 10:17 PM
