Questions about pacesetters and o2 sims
Old Aug 4, 2005 | 02:44 PM
TwoFast's Avatar
Default Questions about pacesetters and o2 sims
Well My pacesetter longtube headers are on their way.....judging by pics that I've seen, It looks like part of the pacesetter ory pipe sits directly under the trans pan...... Will I have to remove the y-pipe evertime I take my trans pan off? Also how does the o2 sims work, are they just plug and play? Also how do you guys think it will sound (pacesetter lt's, ory, Corsa exhuast)?
Old Aug 4, 2005 | 03:25 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
On the o2 sims it depends on which ones you get some are plug and play some you have to splice wires. I think it will sound good especially if you have the sport corsa. I would imagine they would make the pipe go around toward the back so you wouldnt have to do that.
Old Aug 4, 2005 | 08:03 PM
kerndog5.3's Avatar
I just put my pacesetters on last week with Flowmaster 50's and it sounds great. Great horsepower gain too.
Old Aug 4, 2005 | 10:17 PM
duwem's Avatar
do you do this often???? unless you plan on blowing stuff up in there I wouldnt see this being an issue
Old Aug 4, 2005 | 10:38 PM
TwoFast's Avatar
no...but I was just wondering because when I go and have my shift kit, servos, etc installed I don't want them to screw with the y-pipe... I was thinking just clamping the y-pipe in so just incase I want to do something with the trans I don't have to cut the y-pipe off. or if the trans pan will still slide off with the y-pipe in?
Old Aug 4, 2005 | 10:49 PM
EDawg's Avatar
you do have to remove it! and it sucks *** i put mine on and then took it to get my shift kit put in. they said it sucked. they had to beat it off. then have the ends flared back out to put it back on
OffspringZ28
Feb 2, 2012 12:52 PM
BlkNight02
14
Jul 20, 2006 09:55 AM
06GMC1500
Apr 13, 2006 01:38 PM
slow4.8
Oct 18, 2004 04:07 PM
