Questions
Questions
I have an 04 5.3 Silverado, I’m looking to get a little more pep out of the old girl but don’t really know where to go. I have a cold air intake, 160 degree thermostat and dual exhaust with no muffler other than that stock. From what I was told you can get up to 30 hp from electric fan conversation which I plan on doing just want to know how accurate that number actually is. Also been looking into a btr stage 2 cam was hoping someone in here has experienced the drivability of one and how much power they make? Any help would be appreciated!
makes children cry
do you tow with the truck? if so, a clutch fan typically cools better by moving more air (hence why the HD trucks kept using them). if not, have a nut - i believe the 04s might've still had the 28" radiator (versus the 34" on the 05+ that all used factory e-fans), so that's another consideration: either swapping radiators for OEM fans or using a conversion kit.
just read around here - there're plenty of 'sticky' threads in the individual sections that address the most common stuff & provide a great place to start learning & seeing others' experiences.
Long tube headers. TBSS/NNBS intake manifold. Larger TB. Possibly a different exhaust. Cam. Torque converter.
And most importantly a good tune.
wretched73 (08-05-2021)
Edit- To add details about BTR stage 2 cam
BTR stage 2 truck cam 212/218. I have this cam on a 112 LSA in a 6.0 punched .030" over, 370 Ci
Some think it is too small for a 6.0, which it might be, but I love it and many others on this site love it. It drives like stock with a stock converter. On a 5.3 it will act slightly different but having a good tune in it will make it drive like factory
Electric fans add significant horsepower, and MUCH better A/C, but not much torque. Not a bad idea, but maybe not at the top of the to-do-list.
Headers: first mod.
Converter: revolutionizes "leave".
Cam w/valve springs: the 212/218 112° kind of cam is great.
E-fan: probably 12 - 15 HP toward the top end; by no means YYYYYUUUUUUUUUJJJJJJJE or anything, but it's consistent, reduces fuel consumption at all times (who's not to like costing less to drive around?), makes less noise, just altogether a good deal. The KG3 alternator helps this one greatly.
Can't say about the intake manifold. Never done that. Won't comment on it one way or the other.
GEARS are another thing not mentioned. Definitely YYYUUUUUUUUUUUJJJJJJJE in and of themselves.
There are SO MANY WAYS to make a VEHICLE faster without ever cracking open a single engine gasket.
Headers: first mod.
darkirish63 (08-05-2021)
darkirish63 (08-09-2021)
