Pushrods.. What KIND!!
Old Feb 10, 2005 | 12:34 AM
desTRUCKtive's Avatar
Default Pushrods.. What KIND!!
I am going to be putting a cam in TR 220 .551 lift. I know that I need 7.400 length pushrods, but I am wondering if there is any type of pushrod that any of you guys recomend. I have found some trick flows that run about. And two diffrent Comps.
one is:
CCA-7955-16
Pushrods, Hi-Tech, Steel, 5/16 in. Diameter, 7.400 in. Length, Ball Ends, Hardened,
The other is:
CCA-7638-16
Pushrods, Magnum, Chromemoly, 5/16 in. Diameter, 7.400 in. Length, Ball Ends, Hardened
Trick Flows are:
TFS-21407400
Pushrods, Chromemoly, 5/16 in. Diameter, 7.400 in. Length, Ball Ends, Hardened
What do you guys think is the best choice should I stay away from the Chromemoly? Thanks
Old Feb 10, 2005 | 12:44 AM
99Silver6.0's Avatar
Almost any 7.4 rod will work. But Id recommend the TR rods. They are just a tad bit longer to make up for a smaller base circle cam. But they are advertised as 7.4" rods.
Old Feb 10, 2005 | 12:50 AM
SimpleManLance's Avatar
would they be good for a .563 lift?
Old Feb 10, 2005 | 12:54 AM
Oh yea. Just gotta make sure your spring can take the lift.
Old Feb 10, 2005 | 01:06 AM
comp 918's .600 good right?
Old Feb 10, 2005 | 01:41 AM
CAMMIN03''s Avatar
Banned
manley 7.400
Old Feb 10, 2005 | 05:59 AM
one03sierra's Avatar
Formerly one92rs
Talking
manley 7.4's here to.
Old Feb 10, 2005 | 09:23 AM
Jason 98 TA's Avatar
FormerVendor
We stock Manley 7.400 pushrods! Call or IM me if you need a set & I'll take good care of ya
Old Feb 10, 2005 | 10:19 AM
Not trying to still thread, but i wll be installing a 212/218/ .522-.529 cam soon. Will i need pushrods?
Old Feb 10, 2005 | 10:27 AM
ktmrider's Avatar
You won't NEED them with that setup, it's just a recommendation for the LSx motors in general. The pushrods tend to bend/break at high RPM's ( very high like 7000+ ) so most go the chromoly/hardend route. There are also those that shave their heads for more power and require different lengths too.
BTW, most of those who have broken/bent them were M6 tranny folks who missed a shift under race conditions. Most of us truck drivers never see those kinds of RPM's.
