Pushrods
Old Dec 1, 2007 | 06:19 PM
viciousknid's Avatar
Where's the Beef?
Default Pushrods
What pushrod's do i need with a 216/220 525/532 114
Old Dec 1, 2007 | 07:04 PM
RandomHero's Avatar
that doesn't really tell us much. Assuming your base circle is the same as stock and you're running stock heads you'll need some 7.400 pushrods.
Old Dec 2, 2007 | 12:43 AM
regency's Avatar
just use some 7.4's
Old Dec 2, 2007 | 02:07 AM
jakebdb56's Avatar
why not reuse the stock rods? just curious
Old Dec 2, 2007 | 02:59 AM
Where's the Beef?
yea, just a small cam swap, nothing else. Comp Cam XR269HR
I was wondering that myself. I guess they aren't as strong?
Old Dec 2, 2007 | 04:02 AM
Where's the Beef?
Did a lil research...yea, go figure.
the main reason to change the rods is that the cam is most likely a smaller diameter, so you need a longer push rod to compensate.
So i just need to findout the diameter of my cam and stock.
First swap so I'm trying to gather the technical info. Valvetrains aren't something i've delt a whole lot with.
which reminds me i used stock push rods in my blazer with a 465/488 cam and Dart Iron Eagle heads. I should probably check on that too.
Old Dec 2, 2007 | 08:34 AM
sbw9056's Avatar
Your signature does not state what size engine you have. Assuming that you have a 5.3 liter, your stock cam has a base circle of 1.617". According to my calculations, your new cam has a 1.539" base circle. If you have any other questions, you can call Comp Cams help line at 1-800-999-0853.
Old Dec 2, 2007 | 11:03 AM
Phantom's Avatar
11 Second Club
just use 7.400 josh. most people get the new rods because they're hardened and there has been some stock ones bent...
Old Dec 2, 2007 | 11:32 AM
regency's Avatar
hell the stock ones bend under the pressure of a stock cam so just upgrade
Old Dec 2, 2007 | 01:12 PM
Where's the Beef?
Aight den.
didn't realize my engine size wasnt in my sig.
