Pushrod length ok?
Old Feb 11, 2016 | 10:51 PM
6cummins's Avatar
Default Pushrod length ok?
I've got a 09 5.3 Yukon that has BTR DOD delete kit installed, all new ls7 lifters, stock ls2 cam along with LS6 valve springs. Heads are unmilled. Can you tell me if I'd need to run a different length pushrods by chance? I am getting a loud tapping/ticking noise at idle and it does go up with rpm and unsure if it's a lifter not priming or possibly wrong length pushrods as I have seen both cause similar issues. Lifters soaked in oil for 2 days prior to install. Thanks for any help..
Old Feb 11, 2016 | 11:43 PM
07NBSChevy's Avatar
You need hardened pushrods, buy a push rod length checker to verify length.
Old Feb 12, 2016 | 06:06 AM
6cummins's Avatar
I'll get one. Was hoping off top of someone's head they would know if I even needed different length ones bcuz of what I changed
Old Feb 12, 2016 | 06:49 AM
madmann26's Avatar
It's best to measure, always.
Old Feb 12, 2016 | 12:48 PM
gagliano7's Avatar
Make sure you check for exhaust leaks.
Old Feb 12, 2016 | 06:59 PM
Wolftrk99's Avatar
did you torque the rockers and were they all seated?? stock cam stock lifters etc you "should" be fine with stock pushrods
L$X$10
May 17, 2016 04:24 PM
!Hostile!
Jan 29, 2016 05:07 PM
nunleysz
Jan 29, 2016 02:58 PM
Jonblarc7
Jan 27, 2016 08:28 PM
!Hostile!
Jan 21, 2016 09:19 AM
