Pushrod length?
Old May 21, 2004 | 02:21 PM
quicksilverado's Avatar
Default Pushrod length?
What length pushrods fit a 5.3?
Old May 21, 2004 | 02:30 PM
BigKID's Avatar
Stock pushrods are 7.38" so aftermarket stock replacements are 7.40" If you install a higher lift cam with a smaller base circle or deck the heads your length requirement will change.
Old May 21, 2004 | 02:32 PM
mudz5.3's Avatar
Whast he said...
Old May 21, 2004 | 02:57 PM
F8L Z71's Avatar
On my current cam i had tons of preload so I ended up using a 7.350 pushrod and having to use shims.
Old May 21, 2004 | 03:59 PM
one03sierra's Avatar
Formerly one92rs
Talking
i put in manley 7.40 hardened push rods.
Old Jun 9, 2004 | 10:11 PM
Mr. Sandog's Avatar
I was told that due to a smaller base circle, my new cam will require pushrods of 7.450" in order to ensure proper lifter preload, and no valvetrain noise. Does this make sense?
What I find interesting is that I can't readily find 7.450" pushrods anywhere - Summit, Thunder, Jegs - but this shop has them.
JordanH
Nov 6, 2015 07:42 PM
jtphelps289
Sep 29, 2015 12:00 PM
97_ek
Sep 23, 2015 09:16 PM
bisqikss
Sep 8, 2015 03:35 AM
