Procharger oil change
Old Nov 17, 2004 | 07:26 AM
black_yukon's Avatar
Default Procharger oil change
I've changed my oil several times already and everytime oil gets everywhere. Can someone make a brake bleeder type screw that replaces the drain plug that I could attatch a hose to to drain the oil cleanly?
Old Nov 17, 2004 | 08:58 AM
Black Blown 02's Avatar
I use a syringe, with a piece of fuel line attatched, with the small tube out of a windex bottle attatched to the fuel line. That windex tube fits down the dipstick hole perfectly so you can suck the oil out.
Old Nov 17, 2004 | 12:56 PM
Chevmann99's Avatar
I remove the blowoff valve and use a flat square gladware bowl that fits right down under the blower. When the oil is done draining I snap on the lid and can pull the bowl out with out spilling a drop. I like black blowns way too, I'll have to try that. Also one thing I like to do is dump the old oil back into an empty bottle so I can keep an eye out for oil use, which would be an indication of seal failure, so far, so good, last oil change returned about 95% of the oil.
Old Nov 18, 2004 | 04:07 AM
Thanks for the tips guys
Corvette454l88
Sep 1, 2016 01:24 AM
D1SCSS
Jan 25, 2016 10:14 PM
Mossyoakglock
Aug 28, 2015 12:49 PM
madmann26
14
Aug 28, 2015 07:15 AM
Suburban2500
Jul 19, 2015 04:50 PM
