problems with throttle body. please help!!
Old Aug 16, 2005 | 12:54 PM
denalli's Avatar
Default problems with throttle body. please help!!
i just installed my new BBK throttle body and a major problem happened.when i drive normaly everything works perfectly,but when i pedal it to the metal it just dies in its spot and '' reduced engine power '' appers. please help me guys and thank you. by the way my car is a 04 denalli.
Old Aug 16, 2005 | 02:20 PM
BigTex's Avatar
Is this the same BBK throttle body where you have to break into your stock throttle body and pull out the motor to use on the new one?
Old Aug 16, 2005 | 02:25 PM
wait4me's Avatar
LS1Tech Sponsor
Maybe, the calculated air flow table is the cause. It sees you flowing more air at a given tps and is trying to save you. The table can be raised..
Old Aug 16, 2005 | 08:25 PM
denalli's Avatar
yes its the same BBK where you have to break in to pull out the motor . so are you saying that there is no way this throttle would work with my car?
kalikid06
20
Oct 13, 2015 07:37 AM
99bluefirebird
Sep 17, 2015 08:05 PM
Pimpinpete
Sep 8, 2015 07:39 PM
mayko
Sep 7, 2015 12:24 PM
