Problems with nitrous on a Tahoe?
Old Jan 22, 2005 | 08:23 PM
TX Tahoe Z71's Avatar
Default Problems with nitrous on a Tahoe?
Would a window switch be necessary for 100 shot dry on the 5.3 tahoe in my sig? The window switch would be to avoid having the transmission shift an extra 100hp. Could the stock tranny handle it safely without a switch? Also, would using auto 4wd be a good idea to avoid spinning, or would the transfer case die under the extra load? What kind of hp can the 4wd system handle? Any thoughts or guidance would be appreciated.
Old Jan 22, 2005 | 08:39 PM
Black Blown 02's Avatar
Can't comment on the other stuff but, your 4wd system will definately handle it no problem. I just use 4HI, autotrac does this chattering wheel hop thing when you put alot of power to it.
Old Jan 22, 2005 | 08:44 PM
With a 100 shot dry shot I don't think you need a window switch.I know my cousin has run a 100 shot wet for more than a year with no window switch and no broken transmission.He may be lucky or his tranny may be on borrowed time but he drives the truck daily and tows trailers frequently.
Old Jan 22, 2005 | 09:10 PM
TigerFan187's Avatar
You dont have to ahve a window switch but it sure is a damn good piece of insurance in case you bump your rev limiter while spraying. It wouldnt let you. That is a very bad thing if it happens! I got the MSD pn#8969 digital WS(dont have to use th pills) for like $85 and its a nice piece! Plus with a WS you dont spray through the shifts and that is a very good thing! My buddy CRAZYCUTER4.8 sprays 220 shot with just a hurst coil button!
simman22
Jan 21, 2017 10:27 PM
mitchellmade
Sep 27, 2015 08:27 PM
gavin2005
Sep 13, 2015 09:04 PM
gmcyukon
Sep 7, 2015 08:46 PM
06murder
Sep 4, 2015 03:54 PM
