Problem
Old Jul 3, 2005 | 11:21 PM
TURBHOE's Avatar
your good put in a 40
Old Jul 3, 2005 | 11:58 PM
Ruffrider5.3's Avatar
Make sure your relay is rated at what ever fuse you are going to run, those fans will probably draw slightly more than 30 amps so make sure you have the wire and relay to hold it. I however had a brand new fan that was blown before I put it in the truck so it is possible to have a bad fan motor.
Old Jul 4, 2005 | 12:20 AM
parish8's Avatar
single digit dreamer
Originally Posted by Rob'sGMCSS
30 amp fuses are fine you probably have too much juice with the 10 ga wire. you should have used a 14 ga wire. its plenty. on the current draw, i dont know but they do draw some current..
the current draw will be determined by the resistance in the fans and you have to use wire and fuses to match. if you use smaller wire all you will do is create a fire hazzard.
i am with the other guys, try a 40amp fuse. the fans motors are like a dead short right as they start up and probably really draw 60amps plus but the fuses can take a little of that till the fans get spining and the current draw goes down.
Old Jul 4, 2005 | 09:25 AM
white1's Avatar
I would ohm out the fan motors. It sounds like one may be bad. I have a 25 amp on each fan I think. If the fuse is popping when you put it in, there has to be a dead short. If it starts to turn then blows, like everyone else said try a bigger fuse, or it may be a bad winding in one of the fan motors. good luck
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
