Power from just increased compression?
Old Jan 19, 2004 | 12:56 AM
Default Power from just increased compression?
I have a set of PP 5.3 heads milled .040" coming. This would raise the compression to somewhere in the 10.2-10.5:1 range I would imagine. What kind of power boost would come from just the increased compression?
Old Jan 19, 2004 | 05:39 AM
Sport Side's Avatar
shaving .030 will raise your compression .4 higher. Stock compression is 9:4 i think, so since you shaved .040 maybe you'll be near like 10:1
Old Jan 19, 2004 | 09:07 AM
BADMOFO's Avatar
Cuz I AM a BADMOFO
These trucks suffer from KR (knock retard) so much that any more compression may (or may not) cause more detonation. My truck "pings" as it is, sometimes even with the good gas, which inturn causes my timing to get knocked back, resulting in lost power. Its probrobally a real fine line where in my opinion it wouldn't even be worth the cost of the head gaskets. (Unless you plan on running 100 octane all the time!)
Old Jan 19, 2004 | 09:15 AM
BigTex's Avatar
I assume this is for a 5.3 liter truck. Stock CR is 9.5:1 and milling .035 will get you right on 10:1. If the chambers have been cleaned up, the reduction in volume will pull you back below 10:1. I'd guess the TQ / HP increase will be in the 5-10 range from compression alone.
Old Jan 19, 2004 | 12:34 PM
WhiteDiamond's Avatar
I wish I remembered this correctly, but I *think* that each point of compression you raise a given motor, you get somewhere just north of 5% increase in power. This does not include issues you get from increased pinging and pulled timing, which could easily give you a 5% decrease in power or more. This only works up to a break-even point also, probably in the mid teens to 1 compression range.
Anyone know the numbers for 1 point of compression?
Todd
gaps
Oct 15, 2015 02:53 PM
Superman09
Sep 25, 2015 05:55 AM
MA$TER_E
Sep 9, 2015 03:14 PM
01 5.3
Sep 2, 2015 02:17 PM
