power to 4.8L
Old May 23, 2007 | 04:39 PM
hellraiser_LS1's Avatar
it crossed my mind to put in a LS2 but couldn't find one, until now. i am new to this site. it is still up there. my budget for now is under 9K.
Old May 23, 2007 | 04:47 PM
i may just go with a LS2 with exhaust, heads, cam. i don't know that sounds a little easy but i never have done a swap in a truck before. i know that my budget is a good one and anything that i do will be in my budget. i would like it to stay as normally aspirated as i can go. with a swap or not.
Old May 23, 2007 | 06:39 PM
Spoolin's Avatar
GFYS and STFU
Dude for 9K you can get 400 rwhp N/A including the tranny!!! I wouldn't bother with the 4.8L. Not to say you can't make power but you can make more power for cheaper if you swap in a 6L or even go 408. I'd swap in a 4l80e w/shift kit and servo's for $2,000 then build a stout but not built 408 for 5K and the rest for misc supporting parts. If your really hungry, I'd say swap in a 6L for 1,500 get some forged rods and pistons, and some decent flowing heads (2,500)and throw on a Turbo(4,500). And with a smart tune you could be looking at 500rwhp.
Old May 23, 2007 | 06:41 PM
Spoolin's Avatar
GFYS and STFU
If your dead set on your 4.8 look up "KBracing", if interested in doing a swap PM Brain@JPA or Richard@WCCH. They'll both set you in the right direction.
Old May 23, 2007 | 06:53 PM
nightrunner's Avatar
Mr. Obvious
i vote go 6.0 too, i will eventually, awaiting funds
Old May 23, 2007 | 10:47 PM
kdubbz's Avatar
I am also looking to go the 6.0l swap with my 4.8l, I heard that people with the 1999-2000 trucks with 4.8/5.3 need a 2001 or newer LQ4 because it has the short crank, but im not exactly sure if thats right, can someone shed light on this? Thanks.
Old May 23, 2007 | 11:29 PM
litreddevil's Avatar
Banned
read this https://www.performancetrucks.net/fo...d.php?t=392475
Old May 24, 2007 | 06:19 AM
beastmode's Avatar
Import Moderator
Originally Posted by Nick™
well to swap in an LS1 would be a waste IMO, why spend $2,500-3,000 on an aluminum 5.7L when you can swap in a 6.0L iron block for $1,500... which, btw would be my suggestion, it's relatively easy to swap in and it'll give you a better base to work from later... what type of budget are you looking to go with?
i paid $1600 for a cammed LS1 for my truck with 40k miles on it
and wouldnt aluminum be a weight advantage as long as you dont over heat?
lucas287
31
Jan 12, 2021 06:18 AM
Deuce
Oct 30, 2015 08:25 PM
Superman09
Sep 25, 2015 05:55 AM
black00chev
Aug 12, 2015 01:56 PM
Ketis
Jul 23, 2015 12:37 PM
