Possible cam conflict?
Well, I've have had this Crane cam, LS6 Springs, and Hardened Pushrods sitting around for quite awhile. It was going to go in the 5.3 until I just had to get a 6.0l.
I've managed to dig a few more detalis on the cam besides duration and such. As copied from the website...
Main > Camshafts
Part Number: 1449521 Grind Number: HR-208/2941-2S-13.55
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1997 Up CHEVROLET 8 GOOD IDLE WITH INCREASED LOW-END TORQUE AND MID-RANGE TORQUE AND HORSEPOWER FOR CORVETTE AND CAMARO-FIREBIRD APPLICATIONS WITH AUTO OR MANUAL TRANSMISSION. BASIC RPM 1500-5000
Engine Size Configuration
5.7 L V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 2941 @Valve 500 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 294 @Valve 500
Rocker Arm Ratio 1.70
Cam Timing: TAPPET @.004
Lift: Opens Closes ADV Duration
Intake 23.0 BTDC 69.0 ABDC 272.0 °
Exhaust 73.0 BBDC 27.0 ATDC 280.0 °
Spring Requirements: Triple Dual Outer Inner
Part Number 144308-1 SPRING KIT
Loads Closed 82 LBS @ 1.800 or 1 51/64
Open 251 LBS @ 1.320
Recommended RPM range with matching components
Minimum RPM 1800
Maximum RPM 5200
Valve Float 6000
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake (4.0) ATDC 32.0 ABDC 108 208.0 °
Exhaust 46.0 BBDC (10.0) BTDC 118 216.0 °
Remarks:
FIRING ORDER: 1-8-7-2-6-5-4-3
I'll be by the shop on Friday and get the actual grind number to see if this info still stands.
My questions are: How critical is this max RPM of 5200? Valve float occurs at 6000. Would my rev. limiter be OK at near stock (~5800?). Also this is for a Rocker Arm Ratio of 1.7. Aren't the trucks 1.8? Does this affect the RPM range?
Hopefully I didn't throw to much at you all at once.
As always...
I've managed to dig a few more detalis on the cam besides duration and such. As copied from the website...Main > Camshafts
5.7 L V
Minimum RPM 1800
Maximum RPM 5200
Valve Float 6000
Remarks:
As always...
Please get a new cam. With that .500 lift you'll be leaving too much power on the table. Plus, that cam has such slow opening lobes. A more aggressive comp grind will make more power up top and down low. Do yourself a favor and sell that one on ebay and get a comp XE high lift grind.
Thanks BigTex, I figured as much. Not too much of a problem though since I'll need a new cam for when I go blown. Looks like it may be much sooner now since I don't need to get my money's worth out of this cam.
Can't wait to see if the Radix will flow a 409 from some of the more "aggressive" members.
Main > Camshafts
5.7 L V
Minimum RPM 1800
Maximum RPM 5200
Valve Float 6000
Remarks:
As always...
5.7 L V
Minimum RPM 1800
Maximum RPM 5200
Valve Float 6000
Remarks:
As always...
lawhitediamante
Aug 12, 2015 12:14 PM
