Ported TB pics and tune adjustments
Old Apr 15, 2008 | 11:04 AM
  #21
SS_bnoon_SS's Avatar
Sweet, thanks man!
Old Apr 15, 2008 | 11:38 AM
  #22
BlackGMC's Avatar
Resident Retard
Here is what the table looked like stock, vs Stock TB tuned, vs Ported TB tuned. I fudged the values in the extremely High and Low temperatue settings based off of average % error. There was no way for me to get my engine coolant down to -30* or up to 284*....
Kinda interesting when you look at the results... BTW this is the same procedure you use when tuning a cam with low LSA.... Very small changes to this table make BIG changes in the way the truck idles....
Old Apr 15, 2008 | 11:44 AM
  #23
BlackGMC's Avatar
Resident Retard
I will be removing the MAF completely today and installing a fast reacting IAT sensor like the FI guys use and a Hump coupler where the MAF was.... I will probably have to repeat this entire process again after that, from what I have read on EFI Live forum. Then I am going to retune my VE table. I will post up some before and after VE tables when I retune this weekend too.... Then off to the track to see if I gained anything from the UDP, Ported TB and MAF delete....
Old Apr 15, 2008 | 02:40 PM
  #24
Are these wideband results or with the stock narrow band O2?
Old Apr 15, 2008 | 02:45 PM
  #25
BlackGMC's Avatar
Resident Retard
Those results are from the Idle fuel trims, it is a unique EFI Live PID they created that uses STITs and LTITs to create the amount of airflow needed to dial in the desired airflow. Completely different than VE tuning which I do with a WB...
Silveradorst07
Dec 31, 2015 12:04 AM
D3moN plz
19
Dec 9, 2015 11:14 PM
chacho44
Aug 17, 2015 03:36 AM
00pooterSS
Jul 16, 2015 02:41 PM
4B11T
Jul 13, 2015 03:48 PM
