Ported oil pump and ls2 timing chain?s
Tin Foil Hat Wearin' Fool
SO whats the benefit of having an LS2 timing chain I will be dropping the 6L in my truck in the near future and I keep hearing about people putting the ls2 chain on. Obivously a ported oil pump is going to push more oil but is it really needed and worth the money. I will be pushing close to 500hp at the crank hopefully with a 150-200 shot on top of that.
ask parish if he did all that. I don't believe so. Nobody is gonna argue that more oil isn't better, but not necessary. Chain...maybe with such a huge shot(WOW) If you want to do anything that is considerably low cost that will help with that HP plus big *** shot, put ARP rod bolts in it. That much nitrous is gonna "probably" bring more problems than low oil or getting cam chain drag or slack. Just my 2cents, plus depends on how much cash you are looking to spend to get you to race/daily driver ready. Good luck though! Nothing more fun than trying to make alot of power...especially on an extended cab!
Yeah with an ecsb Z71 it is definately a sleeper. I was going to run arp rod bolts anyway but should I do the chain and pump or just spend my money elsewhere?
MY BIGGEST advice to anybody looking to do so much is find a reputable source to get all your specs together. Don't buy a cam here, heads there, oil pump some where else, alky kit way over there...try to find a LSx shop you can build trust with, 150 shot of nitrous is gonna bring fun at first (and I would imagine a **** load of fun), but alot of tweaking and possible havoc later. You keeping that built 60e and 3K stall in there for this adventure? 500HP + 200 shot + 5500lbs=dead 60e (built or not) so start your fix or replace "trans fund" now.
The 60e has everything to hopefully let it live a happy life. It will have a window switch on the nitrous so Im not spraying throught the shifts. I have an engine builder already. I am getting my heads from WCCH just like the ones Moregrip got. I am getting a cam somewhat like my sig I still cant decide between 110 lsa and a 112lsa. I will put arp rod bolts in it. I am going to get a rough mailed tuned from Allen Nelson to get my up to San ANtonio then he will dyno and street tune it so I will have the best tune possible. I am probably only going to run the 200 shot at TR shootout and strip the hell out of it down to like 4800 pounds. My tranny has all the stuff the level 5 FLP trans have and they are holding up will in the ss trucks. It has all the 65e good stuff in it too. Do you think it has a prayer. I will be ditching the 3000 stall for a 3400 Fuddle converter.
Just make sure you are positive that you are headed in right direction when matching heads/cam/and stall. Just ***** and giggles, call each cam company and tell them your plans, then ask for a recommendation on cam specs. See how far apart they are.
Originally Posted by dewmanshu
yeh it'll be fine. Just ask Allen...I am a little pessimistic, I've had my issues with my stuff. The 110lsa or the 112lsa, the 110 will help with low end but have less idling characeristics, and the 112 is the opposite. Can't win can we? LOL Have you asked your engine builder what cam would best suit your needs? great article, http://www.popularhotrodding.com/eng...re/0504em_cam/
the best advice I got from a Cam Company was from Cam Motion.
the best advice I got on a viable Combo was Richard from WCCH, West Coast Racing Cylinder heads.
and lots of good Cam talk on here and Tech
What do you mean by less idling characteristics I want a nice lopey cam. I want his thing to get up and go Im not worried about spinning it up into the atmosphere high rpm range.
BigTex is pretty good w/cams as well. The lower the lsa the more lopey. The longer the duration as well. But you still need to make sure you are within range of that stall and head install or you can live up in the high RPM atmosphere as long as you want but still never produce any usable HP. http://www.cammotion.com/DesktopDefault.aspx?tabid=93
