Ported my OEM airbox.
Originally Posted by Y2K Silverado
If that's want you want to call it? I decided to try and make the OEM airbox flow more air without having the ram-air set up. I used a Dremel tool to enlarge both openings by removing all the excess plastic, both openings were smaller than the foam insulator that's around them and the upper one had real rough edges. I ground down the plastic so it's smooth and the same size as the foam. After I enlarged both airbox openings, I reinstalled the airbox bottom and saw that now the openings in the fender were to small, I mark them with a black marker and removed the airbox bottom. I used a grinding bit on my electric drill to grind the metal off and then filed the edges smooth. I painted the edges on the fender openings to prevent them from rusting and let it dry. Reinstalled everything and drove the truck, it feels good but that could just be me wanting it to work. I would say the I increased the top opening by a total of 8-10% and the bottom opening by 30-40%. This is the fender openings, which I believe were already smaller than the openings on the airbox, when I enlarged the airbox openings, it made it more noticable. I gauge that by the amount I enlarge the fender openings which are now the same size as the airbox openings. Just thought I would pass this on.
Jim
Jim
I think a Radix might give you a little better flow.
Originally Posted by Black Blown 02
It seems like you are pretty concerned about how much air your truck takes in!
LOL!
Jim
Originally Posted by Brandon
did you ditch the pro cold or what was the story on that? i guess i lost track of the thread????/
Jim
gmcyukon
Oct 3, 2015 11:03 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
lxcoupe
Sep 25, 2015 12:36 PM
Closer_2001
Sep 24, 2015 09:15 PM
