Ported heads, grind rocker (intake side) bolts or buy shorter ones???
Well, doing a little long awaited maintenance on the truck... First up was sealing up the rocker bolts... after doing some research on tech, alot of guys buy shorter bolts or grind the stockers.... Since it really only applies to the 8 intake bolts, should i just grind the stockers or buy the edelbrock 8-pack shorter ones for $40?
this is what i am trying to prevent, these aren't my heads but a pic of what it should look like in there.... http://img511.imageshack.us/img511/5...pultti5if5.jpg |
Grinding the stockers would be cheapest while using the Edelbrocks would be cleanest IMO...I'd probably go with the Edelbrocks if you don't mind spending the dough
Well the description of the edelbrocks are studs.... I dunno if they will work with stock heads/rockers... Very few posts on tech and even less on here...
i would just cut a stocker to lenght, then take it to a bolt shop and buy some.
As stated in your other thread buy the Edelbrocks...I am using Scorpion Rockers with them, but Scorpions reuse stock bolts so the Edelbrocks should work with oe rockers...
are they studs or bolts?
1 Attachment(s)
The ones I got were bolts...part #8597
Sweet. Thanks man i will order those. I just did not want to order studs cause that is what the description says.
Originally Posted by BlackGMC
(Post 4535232)
-use rtv for sure... |
I just ordered a set, hopefully they will be here by this weekend :)... thanks again for the advice and PN#
