ported and coated manifolds pics
Old May 7, 2006 | 12:01 PM
Default ported and coated manifolds pics
Manifolds I spent a little time with. Made a little difference I think.
Old May 7, 2006 | 12:07 PM
BlownChevy's Avatar
blownerator
25 Year Member
very nice work! I had thought about that a while ago, now I may do it!
Old May 7, 2006 | 12:37 PM
redaddiction's Avatar
How much weight do you think you shaved off too those manifolds are heavy.
Old May 7, 2006 | 12:40 PM
not much. I dont think all the bungs and what I ported amount to hardly any weight.
The porting was easy; shaving off the heat shield bungs was a PIA.
Old May 7, 2006 | 02:16 PM
greentahoe's Avatar
Did you do this for looks or is there some performance benefit? When doing a turbo is it beneficial to port them (or clean them up) and have them coated? I would think that you would want the heat sheilds with a turbo?
Old May 7, 2006 | 03:38 PM
CrabhartLS1's Avatar
Wow those are really clean, makes me wonder about those guys buying shorties.
Old May 7, 2006 | 04:13 PM
greentahoe's Avatar
Does anyone know the bolt size for the manifold bolts (bolts that connect the manifolds to the Y pipe)???? I thought the bolts would come out with an impact but I guess 300lb/ft isnt enough . I need to get nuts to secure them to the new Y pipe. I went over mine (manifolds) with a wire brush, then a wire attachment on the drill and finally a wire toothbrush before washing them and cleaning them up. They dont look as nice as these^^^ but I coated them with high temp engine enamel and then a couple coats of 1200* Ceramic paint. That should at least keep the rust from coming back.
Old May 7, 2006 | 07:36 PM
Revolutionary's Avatar
They look fantastic I would be really curious to see if there is any gain performance wise and heat wise to doing what you did.. seeing if underhoods stay down a bit.
Old May 7, 2006 | 07:43 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Looks nice. What kind of project do you have going on?
Old May 7, 2006 | 07:48 PM
jblack6527's Avatar
those look sweet, how much would you figure you have in them?
