PO300 code misfire/detected
Old Oct 30, 2003 | 09:58 PM
Wheatley's Avatar
Truck Sponsor
Default PO300 code misfire/detected
Can someone please help me out here.My truck sets a PO300 code which is a randon misfire code.It runs great and idles smooth but I dont understand why it would be setting this code.Its makes no since to me guys.What would cause it to miss some?It obviously is not bad cause I can not even feel it and I can not even hear it at the tail pipes.
Can someone please help me out?Its driving me crazy.
Thanks guys
Old Oct 31, 2003 | 05:48 AM
one03sierra's Avatar
Formerly one92rs
Default yep
Thanks guys
need to get it read with a scanner and it will tell you which cylinder it is
Old Oct 31, 2003 | 08:30 PM
6gear's Avatar
Talk to Allen at Nelson Performance, I have had the same code due to modifications, not realy a misfire but Allen can explain it and correct it. allen@ls1truck.com
Old Nov 1, 2003 | 07:54 AM
L82gofast's Avatar
Thanks guys
I had the same thing happen on my '98. Check the plugs and wires. Also the poppet valves after the injectors are prone to getting clogged so run some techron through it. That's what fixed mine.
If you have access to a Tech2 or other tool you can pulse the injectors one at time. When I did this, the #1 injector would not "click" because the poppet valve was clogged.
Old Nov 1, 2003 | 11:18 AM
Hit Man X's Avatar
Thanks guys
When's the last time you installed some new plug wires? The resistance could be off within them...or your cap could be cracked too. Causing an arc to the other terminal.
Old Nov 1, 2003 | 12:03 PM
Pro Stock John's Avatar
Registered User
Is that the only code you get?
I had that code along with 'bad egr', 'bad passenger front 02 sensor' and what I did was:
-top engine cleaner
-new front passenger o2 sensor
-cleaned egr
Now I just get the egr code SES lite once in a while so I am going to do a new EGR.
How does the Techron stuff work, I'd like to clean my injectors I have 126K on my 99 L31.
Old Nov 1, 2003 | 12:14 PM
L82gofast's Avatar
-top engine cleaner
-cleaned egr
A couple bottles of Techron always cleared up my injectors and poppet valves for a few thousand miles. I would say it was second behind the top engine cleaner.
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
Pimpinpete
Sep 8, 2015 07:39 PM
