plugs and wires?
Old Mar 24, 2008 | 02:03 PM
budhayes3's Avatar
PT's Slowest Truck
Here's the gaps (for stock to mildly modded NA trucks) that I've learned through my research...
Factory platinums = .060
NGK TR55's = .050-.055
Delco/NGK Iridiums = .045 I believe...pretty sure they come pre-gapped.
Platinum plugs should be good for about 60-80kish, TR55's for 15 to 24kish, and Iridiums for 80-100kish, depending on engine tune and a/f ratio and driving conditions.
As for wires, I like both the MSD's and the stockers.
Old Mar 24, 2008 | 09:08 PM
NGK TR 55s N/A motors
NGK TR6s for blown or NOS applications
MSD wires
TAYLORS
Old Mar 24, 2008 | 09:35 PM
TX Tahoe Z71's Avatar
Careful with pulling the wires off the plugs if you plan on using them again. They have a tendency to pull the wire out of the boot, so pull the boot, NOT the wire. You can spray a little WD40 on the plugs and let it soak for a few minutes to loosen them up. Make sure to use anti-seize on the new plugs' threads.
Old Mar 25, 2008 | 12:09 AM
stone150's Avatar
thanks,
i was trying to decide between the
TR55's
TR55-x's
or 12571164 – GM AC Delco Iridium spark plugs
but from your post the the tr55-x and the previous are the same.
would there be any real performance difference from the msd to stockers
Old Mar 25, 2008 | 02:11 AM
Nope, but they look purty. Nobody has gotten on here and said anything about a SOTP difference and no dyno results indicating a different. The stock wires are not really a bottle neck in the first place and the power is only traveling a few inches anyway. I just replaced my wires with a stock set a got from a member with 20k miles on them for the cost of shipping.
Old Mar 25, 2008 | 09:08 AM
BLACKND's Avatar
Performance wise I've never noticed any difference at all on aftermarket wires. Now I will say that my LS based engines have always run a bit smoother on 8 or 9 MM wires compared to the stockers. I've always has a bit of a idle stumble with stock wires on all 3 of my LS trucks. I personally didn't care for the MSD's burned a wire up after 2 weeks of use and never touched a header. I personally like the JBA Power Cables, red is 8mm and blue is 9mm wires-but thats just me.
And when I was running the NGK TR55's I would always only get about 20K miles out of a set before they needed replacing.
Old Mar 25, 2008 | 10:28 AM
stone150's Avatar
I had knew that since the length was never a real factor, so guess i will order the stockers with the long list of other items i want.
i will probably order the stock ngk iridiums, i would like to get more then 20K out of them, is the part # i have listed correct?
Old Mar 26, 2008 | 07:04 PM
stone150's Avatar
are all LS series plug wires the same length?
Old Mar 26, 2008 | 07:06 PM
fastnblu's Avatar
No. Trucks are longer I was told. I had to wait when I ordered mine for that very reason.
Old Mar 26, 2008 | 07:20 PM
chevrolade's Avatar
Go For Msds And Ngks,i Just Did Mine At 140,000 And They Were Toasted
