Which plug wires?
Old Aug 2, 2004 | 11:33 PM
Deckhand's Avatar
Default Which plug wires?
My stock wires are pulling out of the metal clip thing that connects to the sparkplug, and I have to recrimp it every time, these things need to go.
Which plugs wires are the best quality and fit? I also have ASM headers.
MSDs 8.5? Taylors 8mm? Or Taylor 10mm wires?
thanks.
Old Aug 3, 2004 | 08:14 AM
marc_w's Avatar
I cannot recommend TV50's.
My first set - I had some performance problems. Pulled the wires, and two to three of them broke at the spark-plug end. The clip stayed on the plug, and it pulled the end of the internal wire off.
I got another set under waranty. I went to put in spark plugs a little while back. I had another plug wire let go the same way.
I also noticed at the coil end - some wires get a good connection, others don't. The reason is that some of the wires have the metal clip about 3/8" from the end of the boot, while others have it about 3/4" back, so the "snout" of the coil "bottoms out" in the boot before a nice positive CLICK is heard from the clip.
I had a set of MSD 8.5's, and like them a lot... except for the fact that they were too long for my old 5.3 motor. They were the "LS1 truck" set.
I orderd a set of MSD's to replace my TV50's, and I went with the "LS1 car" set. They should be here this week.
Old Aug 3, 2004 | 10:01 AM
Deckhand's Avatar
thanks marc, I'll be going with some MSD's probably then.
Old Aug 3, 2004 | 10:46 AM
marc_w's Avatar
Cool... you should like them a lot.
I also heard that the factory metal heat shrowds can be used on the MSD wires, in case you have any heat problems from headers.
Old Aug 3, 2004 | 03:52 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Yeah, I'm still using my factory heat shields to cover my MSD wires. Keep the springs in there too.
Old Aug 3, 2004 | 04:26 PM
I have the MSD's on with my Dynatechs and love'em no problems at all
Tydriver
45
Oct 23, 2015 09:19 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
Silver8ado
Sep 14, 2015 06:35 PM
spooneralmighty
Sep 11, 2015 02:28 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
