Please Help PCM problems!!
Old Jul 7, 2003 | 02:20 PM
Default Please Help PCM problems!!
2000 silverado ext cab 5.3 many mods, Truck was working fine then i noticed that it would stall at around 5600 rpms WOT so i checked with autotap and it said bank1 sensor 1 was bad, so i got pricing and was going to purchase then i checked again and bank2 sensor2 was bad now. and bank1 was ok. I checked with efilive and the system readiness fails on the catalyst o2's and something else. i reseted the pcm by disconecting the battery and it was back to normal for 2 WOT's then the efilive said no response from interface and it happened again Error was (received checksum is $6A calculated checksum is $DD.
Can anyone Help??
Old Jul 7, 2003 | 03:08 PM
hohl's Avatar
Default Re: Please Help PCM problems!!
Restart efilive and try connecting again. Seems that efilive will choke sometimes not sure what the sequence is that causes it but it does it to me often.
Getting efilive to connect won't solve your truck problems but you should be able to log data and figure it out.
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Wrecker 426
Sep 30, 2015 09:39 PM
