Please Help Me!!!!!
Old Jan 4, 2006 | 05:34 PM
Dark Halo's Avatar
Default Please Help Me!!!!!
I think I am about to pull my hair out. First off I got my crank back from the machine shop today and on the way home it rolls and hit my block ( I had both in the bed of my truck), There is now a very small ding in the crank where the rods connect by the oil journal. Will this hurt anything? Next is I am wonder if my new set up is going to work? I know I will need to check the piston to valve clearance but I was told that the stock LQ9 pistons are not going to hang with my new set up. On the motor it is a LQ9 with patriot stage 2 ls6 heads 64cc 2.02/1.575, a comp cam 230/236 .591/.601 110lsa and all the supporting valvetrain componets, pacesetter long tubes, and 3" exhaust. I also have the 34 raditor, 05 truck fans, and a 200amp alt. The drive train is a 4l80e with a PI 3500 triple disk and a 3.73 powertrax locked rearend, Shifted by a B&M megashifter on the floor. My questions are is there anything wrong with this set up? And do I have to get aftermarket forged pistons? What kind of Hp will I be looking at with this set up? Is there anything I should change? I plan on a stroker later on down the road but not at this time. I don't want to spare any expense when building the stroker. For now I am broke and considering selling the block I have set aside for my stroker. I am open to any and all suggestions
Old Jan 4, 2006 | 06:05 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
IMO the pistons will be fine and so will the p to v clearance if a LS1 can get away with a 242/248 .608 .6~~ 112lsa T-Rex(thinks thats the specs) and no clearance issues you can get away with that cam. Just dont shave anything off the heads. I would bet close to 400 at the wheels. You definately ahve the stall for it. BTW looks like Ill be coming through Friday if I get the motor mostly done in the truck tonight. PM me your phone number that way I can get ahold of you easily if plans change
Old Jan 4, 2006 | 06:20 PM
Dark Halo's Avatar
that sound good, I will PM you my number
Old Jan 4, 2006 | 08:17 PM
v8
17,16,15,14,13,12,11 Drvr
Damn dude more troubles for ya, that sux's, good luck.
Old Jan 4, 2006 | 08:34 PM
Post
I would definately take it back by the machine shop and ask them about the ding on the crank. It's worth the effort in the long run.
Man, I would have had that crank on my floor board and the block riding shotgun!!!!
Sorry to hear about the mishap.
Jim
Old Jan 4, 2006 | 09:29 PM
Next trip back from the machine shop, wrap that crank in some plastic to protect it.
Old Jan 4, 2006 | 10:46 PM
Dark Halo's Avatar
the only bad thing is I already bought all the bearings
Old Jan 4, 2006 | 10:55 PM
Question
Is the price of bearings more than the cost of another rebuild?
Jim
Old Jan 5, 2006 | 05:42 AM
1slow01Z71's Avatar
ONly need to purchase one bearing(two pieces) for it and ur good since it wont effect the other journals of the crank.
Old Jan 5, 2006 | 06:18 AM
Dark Halo's Avatar
Well I also have another crank that came out of an LQ4. I may have him take a look at both and decide from there.
