PCM adaptive learning?
Old Nov 7, 2005 | 08:40 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Default PCM adaptive learning?
To get the best performance do you guys have to reset the PCM if your truck is your daily driver and you want the best times?
After the "tune" i drove as hard and fast as i could, but i cant do that on a daily basis in my town Do you reset before going to the track or does the tune "keep" the first 200 miles stored?
Old Nov 7, 2005 | 08:43 PM
ap2002's Avatar
I pretty sure it keeps it stored...
Old Nov 8, 2005 | 12:38 PM
speed01rcr's Avatar
I've been playing around with dyno tuning here and there. I believe the way it works, is that tuners that sell a basic tune and the hand held tuners give a more aggressive timing curve, and a leaner WOT setting. The threshhold for the WOT fuel curve is also lowered. It is done like this from factory for fuel economy(when you floor it, it takes a few secs before you actually get the added fuel like an accelerator pump works to make full power). Now, where the dyno is going to come in is at WOT(closed loop). This will help to map a new fuel spark curve. At all other speeds, the MAF and the O2 sensors will work to keep the truck running at stachometric mixture, except at closed loop.
Once the memory is flashed in the computer, it doesent take it out after any mileage.
Old Nov 8, 2005 | 01:05 PM
Default Huh?
What are you guys talking about? Like after getting your PCM tuned.....unplug the batt. terminals....reset the PCM and then drive at WOT for a better learn?
I thought it may kill the tune in some applications?
Wrecker 426
Sep 30, 2015 09:39 PM
lxcoupe
Sep 25, 2015 12:36 PM
kalikid06
Sep 20, 2015 07:46 PM
muncie21
Sep 7, 2015 09:55 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
