Parts needed to swap from 5.3 block to LQ4 Block?
Old Feb 8, 2010 | 08:16 PM
Bullitz400's Avatar
Default Parts needed to swap from 5.3 block to LQ4 Block?
Hey guys. Wonder all what parts are need to swap from the 01 5.3 to a newer style lq4. Something about the flex plate and the reluctor wheel? Will ECU plug right in and then just need tuning. Injectors? Manifold? I read all accessorys are in the same position. Thanks
Old Feb 8, 2010 | 08:23 PM
Coban's Avatar
If its an LQ4, then you will need nothing as long as it is cable TB like yours.
If you mean an LY6, then you will need a crank trigger converter (changes 58x signal to 24x), cam sensor extension harness, knock sensor harness extension and I think knock sensors. Also has rectangular port intake so you must use new L92 intake and do that conversion as well. Maybe more.
Old Feb 8, 2010 | 08:24 PM
nickleahy23's Avatar
i swapped from my 2000 5.3 to a 2001 lq4 and just had to swap flexplate to work with my 4l60e...
are you talkin newer style like 07+? I dont believe they had the Lq4 for the 07+ trucks
Old Feb 8, 2010 | 08:43 PM
Bullitz400's Avatar
I heard the 03-05 lq4's had the best internals so i'm sure that year. Or was thinking of starting from a bare block off ebay.
http://cgi.ebay.com/ebaymotors/6-0-G...Q5fAccessories
Are all blocks the same? What would be need to convert if I bought this block and started the build from the engine stand?
ZONES89RS
21
Sep 24, 2015 05:58 PM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
Aboss
Jul 9, 2015 10:28 AM
Sbrown06
Jul 9, 2015 09:21 AM
