part # for 8.1L injecters?
i had a cammed full bolt on 5.7 LS1 running the factory 5.3 injectors and it ran just fine...use a wet shot of nitrous and the injectors wont be an issue. personally i would spend the money elsewhere but to each his own i guess.
I'll spray with the stock ones first and just get my friend to check it out with hp tuners, I suppose that'll be the smartest way to go before spending the bux.
if you spray a wet shot it shouldnt have much of an effect on you injector duty cycle. if you go with a dry shot of nitrous you may need to upgrade depending on you set up and how big of a shot you want to push.
Yeah I'm likely gonna use the wetshot. plus i'll be running a aem wideband to keep watch as well. i'll will be using a 100 shot.
GrooveCityZ71
Aug 31, 2015 12:05 PM
Raylar Engineering
Aug 26, 2015 10:36 PM
FlowmasterMufflers
Aug 14, 2015 01:04 PM
