Paging Parish8
Old May 30, 2003 | 08:07 PM
jasond26's Avatar
Default Paging Parish8
I had a question for you. I have the same msd injectors as you and I also purchased the connectors that splice onto the end of the wiring harness. This may sound stupid but there is a solid pink wire and a another 2 colored wire. Does the pink wire hook to the left side of the injector?
I have looked at the wiring diagram in my manual but was just wanting to make sure before I cut off all those original connectors. Thanks
Old May 30, 2003 | 08:12 PM
parish8's Avatar
single digit dreamer
Default Re: Paging Parish8
i hooked the most common color on the pig tails to the most common color on the harnes, cant remember the colors though. if there are 8 pinks on the pigtails, hook them up to the 8 purples or whatever color is common on the harness, hope that made sence.
Old May 30, 2003 | 08:22 PM
jasond26's Avatar
Well thats the thing, I bought connectors new from summit and they came in a kit containing the connectors and the crimp on ends. They were not clipped off of a ls1 harness. I assume that the wires go in the same order as the original injectors. I'm just A little worried because I am finally getting my truck back together and I don't want to screw anything up. Hell I am reading my own reply and I am confusing myself.
Preshr
Sep 6, 2025 09:15 AM
Stainless Works
Oct 8, 2015 12:01 PM
carid
Sep 10, 2015 09:07 AM
