Paging Parish8
Old Sep 13, 2004 | 11:23 PM
MR.QUIK's Avatar
Lightbulb Paging Parish8
Just got a few ? about your setup how hard was the installation and where can i find some 57-lb injectors and do u think the cam u r running will work for me my truck weighs 4200 pounds 2 wheel drive got a 3500 stall 4.10 gears stock 6.0 lQ4 I talked 2 Dave at cmotorsports total coast 4 my setup was $5495
Old Sep 14, 2004 | 07:11 AM
GMC SKI's Avatar
The Install wasn't that Bad on the Kit
There are a few Tweeks on the downpipe I hope they have taken care off other than that make sure you have everything before you start
As for Injectors Get a Set From www.racetronix.com
you'll need to shim the rail to get em to work also need a set of connectors to splice in there
The Cam will work on your setup I would go with a lower stall on your setup
that Convertor is gonna flash way too high
my yank 3000 was flashing to 5100rpms
You'll want a lower stall but i would try it out if your on a budget
Ideally you want something near a 2800rpm it will flash higher with boost and load the turbo down nice makin some crazy boost
Hope that helps out a bit
Old Sep 14, 2004 | 10:44 PM
MR.QUIK's Avatar
ya thanx i will try 2 sell my converter then and get a 2500 or 2800 dave told me about your setup u r out of ontario
Old Sep 15, 2004 | 12:13 AM
OUT2WIN's Avatar
Parish8 has 3.73s in his truck instead of the 4.10s doesnt he?
Old Sep 15, 2004 | 06:21 AM
parish8's Avatar
single digit dreamer
yep, 3.73 and prety tall tires too. 31-32"
Old Sep 15, 2004 | 11:40 PM
OUT2WIN's Avatar
You wanna trade your 4.10 posi for my 3.73 posi and I will throw in some cash too?
Preshr
Sep 6, 2025 09:15 AM
Stainless Works
Oct 8, 2015 12:01 PM
carid
Sep 10, 2015 09:07 AM
