Pacesetter LT guys
#32
My friend has the pacesetters on his truck and it sound awesome which is the reason i am going to by some from Texas Speed and Performance along with the Off Road Y pipe.. They are better than most..
#33
Originally Posted by ap2002
I thought you were going to move to C.S. to go to school, if so then you dont have to have cats in C.S. from what I understand, maybe Farmbeau will chime in....
In my county, Montgomery county, they do emissions testing, but only on vehicles that are so many years old(10 years old I think?). Otherwise, they just plug into the OBDII port and make sure all systems are in the "ready" state....even if no codes are present, all systems must be in the "ready" state.
#34
i see, im pretty sure here in the ft country they do emissions...alot of people get the cats and just bore them out clean so they have the look without restriction but a set of high flow cats work pretty well i understand if you MUST have them, but you could always find a crooked inspector somewhere
#35
gains from cat removal is only .1 so IMO removing the cats is not worth it, they flow fine and will save some trees somewhere, getting a cated pipe from the collectors to the cat back is the problem...
#37
question...what is the flange diameter and bolt pattern where it hooks onto cat back system...will a after market catback system hook right up to the ory pipe or do you need to change out the connection....
#38
They dont have flanges on the collectors. The Y pipe (off road Y) is a slip fit design that just slips on the collectors.
#39
