Pac 1215 or 1218
Old Feb 13, 2020 | 01:36 PM
Tim England's Avatar
Registered User
Default Pac 1215 or 1218
Ok just picked up a new pre-owned cam. Specs are 218/222 112+4 with. 587 lift. Need to decide on springs. Have read the spring rate on 1215 and 1218 are the same but 12q5 has lower opening pressure. Seeing as this is going in a sub 6k rpm Yukon, the 1215s would be better suited?
Old Feb 13, 2020 | 01:38 PM
arthursc2's Avatar
1219s are good too
Old Feb 13, 2020 | 02:52 PM
Registered User
Its a Cam Motion custom grind. So I asked them the same question and they said they'd "like to me in in a Cam Motion .625. Looks the same as the 1219s. Question is why go higher lift and spring rate and pressure for a daily driver?
Old Feb 13, 2020 | 05:01 PM
arthursc2's Avatar
better high rpm valve control
Old Feb 13, 2020 | 10:21 PM
Registered User
I see 5800 rpm once every 2 weeks if that, lol. Don't need high rpm valve control at low to mid rpm.
Old Feb 14, 2020 | 12:09 AM
arthursc2's Avatar
Sounds like your mind has been made up for a while then. Buy the cheapest set you can find
Old Feb 14, 2020 | 06:04 AM
Registered User
Minds not made up just looking for someone with knowledge to give share some.
Old Feb 14, 2020 | 09:39 AM
MikeGyver's Avatar
I must be one of the few people that ruined my engine because of a broken single coil valve spring . I'm sure it was just bad luck.
marineusmc4
Nov 7, 2016 09:55 AM
69Camaro427
Oct 16, 2013 07:06 AM
monchis
Aug 24, 2013 01:59 PM
Atomic
Oct 28, 2010 08:57 PM
BlackGMC
20
Oct 17, 2010 10:00 PM
