P0336 code need help
Old Jul 7, 2015 | 11:37 AM
chevyl33's Avatar
Default P0336 code need help
I have a 5.3l swapped into a 89 c1500. I just put a new motor in the truck do to a cracked block an every since I put it in the truck don't start an throws a p0336 code.
Truck mods:
216/224 cam
918 springs
New timing chain
Tuned by Blackbear
Iv replaced the crank sensor didn't fix it, checked fuel pressure good, did crank relearn didn't fix it, checked wiring all checked out good
Anymore opions I can try
Old Jul 8, 2015 | 11:42 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Where did this "new" motor come from???
Where did the new sensor come from???
Have you checked the crankshaft end play???
Old Jul 9, 2015 | 08:28 AM
chevyl33's Avatar
Yes checked crank play an the motor came out of a wreaked 02 Silverado an the sensor came from my local parts store
Old Jul 26, 2015 | 04:58 PM
chevyl33's Avatar
Anyone have any ideas
Old Jul 26, 2015 | 10:06 PM
How did you do a crank sensor relearn if it won't start?
Old Jul 27, 2015 | 08:22 AM
chevyl33's Avatar
It will start an run sometimes but you have to hold it around 800 to 1000 rpms for it to stay running because it serges.
Old Aug 24, 2015 | 08:21 AM
chevyl33's Avatar
Got the problem fixed ended up being the ecm
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
Pimpinpete
Sep 8, 2015 07:39 PM
