oxygen sensor
Old Feb 27, 2005 | 07:03 PM
skindog39's Avatar
Default oxygen sensor
wouldn't a truck with a stock single exhaust system only have ONE frontal oxygen sensor? or am I wrong? If I am not, I am about to put a set of longtubes on and am wondering what to do about the other header plug hole...do I just plug it...if so does someone make plugs for that? Thank you guys so much! I have posted about exhaust a lot lately and you guys are awesome!
Old Feb 27, 2005 | 07:06 PM
SD-Silverado's Avatar
My stock 5.3 setup has 4 oxygen sensors. 2 each side. 1 before and 1 after the cat.
Old Feb 28, 2005 | 06:35 AM
guffsx125's Avatar
There should only be one hole in each header. That is the front O2 sensor and you have to keep that one. If you are going to remove your cats then you have to run O2 sims or get a custom tune with the rears turned off.
Old Feb 28, 2005 | 07:34 AM
skindog39's Avatar
Default extensions?
I just got my set of long tube pacesetters in....do I need o2 extensions?
Old Feb 28, 2005 | 08:23 AM
FILE's Avatar
My ASM headers are long and I did not need extension. I doubt you will need them on the pacesetters.
Old Feb 28, 2005 | 01:51 PM
guffsx125's Avatar
I was told you don't need them.
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
Wrecker 426
Sep 30, 2015 09:39 PM
WICK3DxGATA
Sep 24, 2015 06:56 PM
