Overlap and you......
Old May 10, 2015 | 05:18 PM
Mark Johnson's Avatar
Default Overlap and you......
Hey guys- as most of you know I'm piece- mealing a cam together refining the specs as I decide on displacement and components. The BIG question is about overlap; is it measured from the seat or at .050? When does ovelap begin to affect vacuum? Trying to stay on the conservative side at these higher elevations..................
Last edited by Mark Johnson; May 10, 2015 at 05:22 PM. Reason: Too slow...........
Old May 12, 2015 | 07:55 AM
joelster's Avatar
10 Second Club
What duration are you looking at? If you want a small cam with around 220/230, you could grind it on a 104 and still have plenty of vacuum.
Old May 12, 2015 | 08:04 AM
Vortec350ss's Avatar
with a 5.3 even as little as -10 of overlap you will notice a choppy idle. You will have plenty of vacuum, but the idle will chop pretty good.
Overlap is measured at .050.
Old May 12, 2015 | 08:25 AM
oh no- very short durations, like around 198* @ .050. Not looking for chop, just trying keep what precious little vacuum here at 7,200 ft..............
Old May 12, 2015 | 08:45 AM
Oh man you will be fine...
a mild cam in that truck that would work well for you would be something along the lines of a 212/218 low lift. Its a 114 LSA with 2* advance I believe. Vinci offers some small cams that would work well also. Be careful with a cam that has a lot of advance if you dont plan to run headers as it can disrupt your intake flow opening the valve too soon.
Old May 19, 2015 | 10:58 AM
Cool-
this is for a 4.8 project I'm cooking up down the road. DD, maybe/ probably a little added zing. TB torque converter fer sure..........
Old May 19, 2015 | 11:28 AM
Fast355's Avatar
Overlap can be measured seat to seat as well, usually .004 or .006 depending on whose specs you are looking at. With a 23* head 10-40* works well for towing, 30-60* for a mild street cam and up to about 50-75* for hot street setups. Anything beyond that is Strip/Race territory. Keep in mind the better the head the wider the LSA it will want for a given duration.
Daily driven, mild LS engines seem to respond well cams in the 112-116* range for LSA when running modest durations. High altitude is going to naturally reduce cylinder pressure and idle vacuum.
OP, I would probably do a set of milled/ported LS6 243 style heads first to get the compression ratio up then make a cam change. I would likely run something around 212/218 @ .050 on a 112* LSA and advanced 4*.
Then again you could always do as I have done and swap the junk vacuum booster for a hydroboost setup and run the lumpy cam of your choice.
Old May 19, 2015 | 11:31 AM
Fast355's Avatar
Originally Posted by 2001 Sierra
Cool-
Yank SS3600 converter, 4.10 gears, Hydroboost, milled/ported 243s, long tubes, a 220/228ish cam on as tight of a LSA as you dare and spin that 4.8 a little.
Old May 21, 2015 | 08:55 AM
Holy mother f*** I'm not bracket racing. I purposely sought out a truck with the T engine(*706 heads) for their small valves in the quest for gas mileage. Just lookin' for a little more zing, I have no business in the stoplight to stoplight drag race scene............
Old May 21, 2015 | 11:19 AM
Fast355's Avatar
I think we all assumed you were interested in performance without a massive driveability sacrifice. For a stock truck, the best fuel economy is likely with a stock cam considering about the smallest off the shelf cam I can think of is a 206/212 comp on a 115* LSA and even Comp advertises it as making midrange and top-end gains. Then again I had a Comp XFI grind in my 5.7 Hemi Ram and it got better MPG than it did with the stock cam. It was 212/212 @ .050 on a 114* LSA and 110* ICL. With 4.56 gears, APS 2,800 rpm converter, heavy 32" P305/50R20 tires, long tube headers, the Comp Cam and SCT tuning I frequently saw 18-20 MPG on the highway.
